Head porting companies
Old Jan 17, 2008 | 10:12 AM
duff0000's Avatar
Default Head porting companies
Im currently looking into getting my head ported and browsing possible companies to do it. It seems the price range varies alot depending on how far you want to go.
A little backgound on my setup: CTSC'ed running a 7lb pulley and front mount intercooler.
Ive called a local repected shop that has done honda head work in the past anf they wanted $300 for a full head porting, i do not think they do any intake/exhaust valve jobs though.
Portflow.com
disassemble/ clean/ inspection
port & polish
full radius competition exhaust valve job
multi-angle competition intake valve job
de-shroud valves & polish chambers
surface deck to mirror finish
assembly / new seals included ------------------$1000
Laskey racing
stage 1 Hot tank, crack check, competition 3 angle valve job, mirror surface, new seals, assembly $350 shipped
stage 2 SuperTech SS valves, dual springs, ti retainers, hot tank, 3 angle valve job, surface, new seals $875 shipped
stage 3A PortFlow port, polish & Stage 1 work using your valves, springs and retainers $1050 shipped
stage 3 PortFlow port & polish, SuperTech Stainless Steel nitride coated valves, dual valve springs, titanium retainers, competition 3 angle valve job, surfaced to a mirror like finish and assembly $1600 shipped
ALANIZ
Streetmaster Headwork:
Complete visual inspection of complete head.
Check all surfaces for straightness.
Complete disassembly.
Inspect all valvetrain parts for wear.
Degrease and clean head of all oils.
Street port and polish which is: (bowl port, gasket match1 inches into runners only. Polish, deshroud and debur all chambers.
Street Master valve job.
Resurface and hand lap head surface up to .020 material removal.
Reassemble complete head.
New valve seals.
-------------------------------------------$975
Competition headwork
Remove all studs and lap all surfaces.
Degrease and clean head of oils.
Baseline flow bench test.
Full Competition port and polish head.
Deshroud, polish and debur all chambers.
Install oversize seats on intake side.
Install oversize valves on intake and exhaust.
Competition valve job.
Resurface and hand lap head to customer specs, or up to .030 material removal.
Final flow test with data sheet.
Reassemble complete head. Final CC check.
Includes new valve seals.
----------------------------------------------------$1850
I guess my question is, Is it worth the extra 600+ for the competition/top of the line headwork? My budget is $600-$1200 and I would be perfectly happy with 330-360+whp on my setup with 9lbs with a ported head. I currently have new ap1 exhaust retainers and ap2 intake retaners and all new keepers. Also is it worth it to get all new valves?
Old Jan 17, 2008 | 06:50 PM
fperra's Avatar
I have a head that has been built by Alaniz. Ported and polished with oversized valves and Ti retainers. This was built from a new factory head and has only about 4000 miles on it. If interestes, let me know and I will remove it from my sprare engine. But it will cost $850 plus shipping.
Old Jan 17, 2008 | 07:25 PM
SPECIAL-OPS-S2K's Avatar
THAT IS A STEAL! I PAID WAYYYYYYYYYYYY MORE.
What are the specs? how oversize are the valves?
Old Jan 17, 2008 | 07:36 PM
duff0000's Avatar
Special ops, I dont think his had the competition headwork dont to it, just a mild port job or the streetmaster work. What headwork do you have done by alaniz?
Whats everybodys opinion on Ti retainers, Ive head from several people these wear thin at around 20k miles and need to be replaced. Not somthing I would look forward to doing even though im pretty sure I could just do it by removing the valve cover.
Old Jan 17, 2008 | 07:59 PM
fperra's Avatar
All the info on this head work is posted here:
https://www.s2ki.com/forums/index.php?showt...0&#entry4120047
Old Jan 17, 2008 | 08:02 PM
fperra's Avatar
Wrong. It was the Competition Headwork.
Old Jan 17, 2008 | 08:16 PM
duff0000's Avatar
^wow thats a great deal, Pm'ed
Soul Coughing's Avatar
looks very interesting! trying to rationalize if i could pick this up! What numbers did you put down with that setup? The thread you posted ended before you got it dynoed!
Old Jan 18, 2008 | 05:11 AM
PeanutButter's Avatar
Whats all included?
Old Jan 18, 2008 | 12:55 PM
mys2k3's Avatar
I'm curious to know what kind of numbers a ported and polished head are putting down. I've heard that our heads are better off getting the valves, springs, and retainers done because there isn't much of a gain from the port and polish.
