Help fitting relocation kit
Hey guys have been breezing through the turbo kit install (fullblown stage 2) and till now everything was moving along smoothly.
The oil filter relocation kit is also from full-blown.
The fitting on the block went on fine with no issues but when I went to try adapt my stock oil cooler onto the relocation block (filter side) the threads are tottaly wrong so I tried fitting just the oem filter on and the threads are Also wrong for that too.. Not having any instructions for anything doesn't help either! So I am stuck here.
I want to retain my stock cooler to save on costs for now I also have a sandwich adapter for my gauges which suits the oem thread. Any help would be very much appreciated! I can already see a lengthy downtime since I am located in Australia
If it is anything like the Full Race relocation kit that uses the canton adaptors, It's not metric thread.
My FR kit used a gm thread or more specifically, an older Corvette filter. They said it was because the are bigger.
Can you take a picture? I'm curious to know if it's a canton adaptor.
Sent from my HTC Glacier using Tapatalk 2
U need the oil bolt from a crv I think. Then relocation block will sit snug against block. Then u need a filter like the Bosch 3332 or fram 3506. Instructions would be nice but once u get the bolt all falls into place.
As for the Oem cooler just scrap it.
Yeah I got the crv oil bolt. That part is all good. It's the filter side that's got me stumped. Bosch 3332 or fram 3506? Is that the compatible oil filters? I don't necessarily mind dumping the oem oil cooler. How can I get my defi oil pressure/temp gauges going?
Ok update: found an equivalent replacement oil filter here in aust didn't realize that some of our cars run the corvette engine. So that's solved!
I am happy to remove the stock oil cooler but I am still stumped on how to incorporate my defi oil/pressure sensors. They were on a sandwich adaptor.. The sandwich adaptor doesn't thread on the relocation plate.
What can I do guys?
What can I do guys?
