High Idle?
Old May 27, 2010 | 05:29 PM
  #51
Ian300D's Avatar
Also I've heard from tuners AEM can do some weird things.
Old May 27, 2010 | 05:37 PM
  #52
JoeyBalls's Avatar
Dude its the METH. I was at low boost just to see if the METH would cool down the charge piping, so basically cruising in low boost just to spray a whole heap load of METH and now my car idles high . It went away for a few hours though it idled high
Old May 27, 2010 | 05:43 PM
  #53
siadam's Avatar
Negative.
I started out with a brand new TPS, and didn't even get on it, before it started acting up.
It saw zero meth...and is still showing those problems.
  #54
*JG*'s Avatar
I know on a bseries motor the iacv can actually loosen itself inside the housing. Is it possible to take the old one apart and see of there is a screw to tighten down?
Old May 27, 2010 | 05:44 PM
  #55
Spoolin's Avatar
Sounds like the Meth messes with some electrical components over time maybe? Gum-up in the smallest things maybe? My tuner/friend did tell me to stay away from Meth because of wierd things that can happen to components over time. This sucks man. I hate when things start acting wierd and you have to go chasing down all sorts of things.
I bet it ends up being something stupid and simple.
Old May 27, 2010 | 05:49 PM
  #56
JoeyBalls's Avatar
Originally Posted by siadam,May 27 2010, 05:43 PM
Negative.
in that case I apologize.................
Old May 27, 2010 | 06:04 PM
  #57
siadam's Avatar
after replacing the IACV & TPS sensor, nothing else really in the way that the meth sees before it goes into the motor except the IAT, and that doesn't control idle.
I did a compression test when I first noticed this, and I even did a pressure test on the manifold and didn't see a problem.
Could I get someone to post up a screenshot, or even email it to me of your idle settings in your AEM please?
Old May 27, 2010 | 06:12 PM
  #58
Spoolin's Avatar
Actually, if the IAT's are wack, you can have idle and driveability issues I believe. A/F's I believe are controlled with the IAT temps if the AEM is setup to adjust things under normal driving.
I'd send you a screen shot of mine but I dont have a way to hook up to my AEM anymore. Only my tuner has the software on his PC.
Old May 27, 2010 | 06:25 PM
  #59
camuman's Avatar
download aempro from aempower.com forums and hook to box. tune is in box and it will download when you connect
Old May 27, 2010 | 06:38 PM
  #60
Spoolin's Avatar
I would but my normal size laptop that I used to use is broken and the only laptop I now have is a netbook (those mini laptops) and I cant hook up my aem to it because it doesnt have the serial port that it uses and I dont have an adapter.
