HKS ssqv on Comptech SC
If you have, please post your opinions and review of the setup. I am going to go that rout and weld a nice flange up in place of the godzilla spot.
Thanks guys. |
Yes I had it and it worked great. I modified the stock BOV flange and put the bov there, sorry i don't have pics. Sound wise it will make a fluttering noise at partial throttle too.
Here's a vid of the car with the SC and HKS BOV with stock exhaust. Hope it helps. I got killed by the vette at the end. http://www.youtube.com/watch?v=AIEwH-dSPow |
Thanks for the post. I was wondering if it would flutter. Trying to stay away from that. The ssqv is know for low boost level flutter. Hmmmmm. Might go with the synchronic or godzilla then.
I have it with my UR FMIC, sounds fine, not too much flutter.
FYI diaphragm based BOV's are not meant to be used with constant airflow superchargers.
They react with an impulse. You will not have good results with the HKS on an S/C, even with its max cool factor. |
Ivan, I have a TurboSmart XS that came with my kit. Is that okay to use? I think its an Australian one where you can adjust the sprint pressure.
If not which one should I switch to? |
You can try it if the idle noise doesn't drive you crazy.
I am not sure what type the TSXS is. They will all work, don't get me wrong, they'll just bounce back and forth continuously because S/C boost never goes away. I use Syncronic and heard good things about Godzilla. |
Synapse synchronic bov all day. Death to the diaphram!
Moar about the synchronic please gents. The only vid or feedback i have come across is the 9 zillon year old synapse vid on youtube.
Thanks for the responses. I appreciate your time in offering your feedback. |
Originally Posted by teamvalorracing
(Post 21184509)
Thanks for the responses. I appreciate your time in offering your feedback. Here's a decent website for literature. http://www.motoiq.com/magazine_artic...ter-valve.aspx |
| All times are GMT -8. The time now is 11:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
