Hks supercharger power lose
#23
As as far as the hks kit, I have very little experience with it but there is a big reason kw went away from that design and the hks failures continue to push that narrative
#24
Its true the Rotrex is slightly more efficient up to a point, and has been shown to generally offer about 1psi worth of equivalent output over a lot of the power curve at the same boost pressure comparatively. However, once you get into the upper ranges of both blowers, the Novi can easily be over spun and take it, running on alternative fuels to get over 500whp. A few guys have made around the 600whp mark with the Paxton/Vortech blowers at the proper trim.
#25
That is arguable.
also feel free to show me a novi at 12.5psi putting out 451/301 to the wheels on pump gas
#26
Once you start over spinning a novi1200 your going to be running into the same reliability concerns as the rotrex and you can just as easily overspin a rotrex with a 90mm pulley and still make more power. Rotrex has proven to be more efficient than any other blower on the market across multiple platforms. And I would argue that 600hp on a rotrex would be more reliable than 600hp on a novi and at a much lower cost
