How to change oil on Paxton 1220SL?
I recently got my supercharger rebuilt from Paxton and it's almost at 3000 miles since the oil was changed from Paxton. How do you change the oil on the supercharger? and how often are the intervals for changing? I read up that 7500 miles was the max, but i couldn't find any documentation on how to change it, where the drain plug is at, etc. Can this be performed while the supercharger is on, or would it have to be removed?
Thanks for the help guys!
( i had mine put on my oem hood damper plastic hook).
find the line, at the end u should see a twist of screw, take it off, leak the oil , let it drain for a few minutes, than close ,attach ur line, refill the bottle, done... n go
You are going to drain it and say "damn, that's not very much oil". That is expected. It is only about 4-6 ounces. Make sure you have the correct replacement fluid before you drain it.
