How I rebuilt my Paxton Novi 1000
I promised a couple of members on the board that I would write a summary of how I built my Novi 1000.
This is not a HOW TO! it's simply some pictures and information on how I did mine so please be aware this may not be the correct procedure.
I thought mine sounded loud so I wanted to change the bearings, hence why I rebuilt it.
First I removed the supercharger from the mounting plate:
Removed the pulley and washer:
Then I removed all the allen key cap head bolts holding the rear casing on:
View of inside:
I removed the three spring washers and two spacing washers form the output shaft bearing. I placed these in the insert in the housing plate for safe keeping:
Output shaft bearings:
Input shaft bearings:
Then I lifted the input shaft assembly out:
Removed the spring washer and stored it for safe keeping:
I then flipped the casing over and removed the volute:
View of inside:
Now off I went to my workshop (well my work's workshop:
Picture of parts:
I then placed the casing into a vice (with the output shaft/bearings still attached), heated the impeller with a blow torch then removed the locking nut and impeller. once you remove these the output shaft assembly just pops out:
I melted the old output shaft seal but this was getting replaced anyway:
Then put the washers with the impeller for safe keeping:
I then removed all bearings with bearing pullers
I removed all four bearings and refitted them using a bearing induction heater. If you haven't got a bearing induction heater just heat the bearings in some fresh motor oil to 100'C in an oven!:
WHEN ISTALLING THE NEW BEARINGS MAKE SURE YOU INSTALL THEM IN THE SAME ORINTATION AS REMOVED! NUMBERS FACING OUTWARDS!
I then removed the input & output shaft seal with a press and hand tools:
I then pressed in the new seals - Please note; you can easily damage the seals so please be cautious!!! You need to heat the casing with a blow torch (or this is how Paxton recommend). You must press the output shaft in on the inner race/sleeve ONLY! I used some 17mm round bar for the output shaft. The input shaft can be done by hand
I then laid all the components out and re-assembled:
Once I'd reassembled all the parts within the casing. I installed the rear cover with the allen key bolts. Then placed the input shaft into a vice and clamped it. Heated the impeller with a blow torch and dropped the impeller back onto the output shaft.
Like this:
Then I screwed on the lock nut and tightend.
You can now re-install the impeller, volute and pulley.
I then fitted the charger to the car. I spun the input shaft by hand (with the belt removed), I could hear the impeller touching the volute so I clamped the input shaft with a pair of stilsons and tighten the impeller locking nut. I tightened it to what felt tight to me. Please go careful as you could break the helical gears if excessive force is applied!
I then marked the lock nut with a line to see if it moves - which it hasn't so far.
Picture of parts:
Like this:
For information:
I bought the bearings from a UK supplier no problem, they cost my £150
Parts I used:
X2 SKF 6206 C3 bearings
X2 Barden 203H bearings
X1 input shaft seal
X1 output shaft seal - 30mm
Seals can be bought from here:
http://www.superchargerrebuild.com/paxton/
I did purchase a seal from JBO but I didn't like the type of output shaft seal so opted for the OEM type from the above.
Any questions please ask, I typed that lot as quickly as possible
Parts I used:
X1 input shaft seal
Great information! I recently rebuilt my Paxton 1000 as well and my impeller only had one shim on it, compared to two on yours! Seems that there is quite a bit of variation with their builds. Also, from my research, the impeller nut needed 35 ft/lbs, or at least, that's what a paxton manual said. Thanks for the write up!
Nice write up.
As long as you dont over spin the blowers rated speed, or over tighten the pulley belt, ive seen 150k+ miles on these units before a rebuild was needed. They all sound like a coffee grinder at idle.
