How to install fast turbo firewall port
So I bought a aem oil psi gauge and a fast-turbo.com firewall adapter. I took the stock switch out but it doesn't look like it fits the fast turbo oil block. Can anyone point me in the right direction on installing this.
MY07 S2000
Fast turbo firewall oil block
AEM oil psi gauge.
MY07 S2000
AEM oil psi gauge.
MY07 S2000
AEM oil psi gauge.
MY07 S2000
AEM oil psi gauge.
This is what I did. I took the block adapter and put that in the block. Took one of the fittings and put it in to that. Then the Goodrich line, then the Oil block. I put the AEM OIL PSI sensor on one port. closed off one of the ports and then Tried fitting the Stock adapter on the last one. It barely screwed in, and when I did start the car it leaked. I didn't think it was this complicated. Im hoping I didn't strip the block.
Based on the picture from fast-turbo (might just be an example photo; not sure), you may need an adapter for the stock oil pressure switch to thread into the brass distribution block. The only leak occurred at the brass distribution block?
cbender
08-13-2007 10:46 AM
