how much does a turbo s2000 weigh?
I know a stock s2000 weighs anywhere from 2760 to 2880 lbs. It would be nice to know what a turbo s2000 weighs. And please list if its ap1 or ap2. I believe mine will be in the 2700lb range as I am running open downpipe (no exhaust) no spare or jack and a mini battery.
I weighed mine a while ago with the soft top and it was right at 2780 lbs. Soft top is now gone and only the hard top, so it may have dropped it down to about 2750 lbs but with the added 50 lbs of the T56 trans and SFI bell housing, it's probably back up to about 2800 lbs. With things that are removed that aren't needed like the evap canister, air pump, spare tire and things when boosting, I'd just count on it weighing somewhere around 2700-2800 lbs.
In street trim mine was right at 3000lbs. I did have a cage in the car. OEM hardtop, with soft Top still installed.
Weighed at several different tracks.
Carey, did you have an issue with the OEM hardtop pulling down tighter on the passenger front latch over the drivers side? I got the OEM hardtop strikers but for some reason I can't get the drives side to pull down as tight and it sets up about 1/8" higher and is annoying me. I've tried adjusting it as much as I know how but can't figure it out. May just have to got to the Ballad hard mounts.
In race trim it was 2350 with me in it.
Carbon doors with glass and power windows. Rockstar hard top. Back half. 25.1 spec chassis. Still all the stock stuff from back of the seat forward.
