ID 1000's and E85?
Old 11-03-2009, 11:21 PM
  #21
STL2SLW's Avatar
Originally Posted by sbrodacz,Nov 3 2009, 06:56 PM
STL2SLW is running a walbro 255 fed into a surge tank and then a bosch 044. He's running ID1000's. He's making 620hp with a 6262.
STL2SLW, hope you do not mind me posting your info. Martin, you should be able to make 600-630whp with the ID1000's and E85 from what I'm gathering so far. That works for me for now.
Hey man its not a problem. Im also running 90ish psi fuel pressure.
Old 11-04-2009, 07:52 AM
  #22
Shftat9k's Avatar
STL2SLW what kind of boost levels did it take to get those numbers? Did FB tune the car again? I saw your dyno with the UR log manifold. Honestly I am still shocked you pulled 49xwhp on only 19psi with a log manifold and a smaller turbo. All on e85 with a single pump. WOW!
Old 11-04-2009, 09:35 AM
  #23
CourageOO7's Avatar
I am so frustrated. I cannot find enough E85 stations in my area so that I can make the jump. I'm nowhere near your power levels but the idea of running much cooler is definitely inviting as I am trying to build a cool running and reliable track whore.
Man, these Injector Dynamics injectors are quite nice, aren't they? A 2000cc injector that idles well at less than 10% duty cycle? RC Engineering better get their act together cuz ID is here to stay!
Old 11-04-2009, 09:36 AM
  #24
CourageOO7's Avatar
Hell, my 750cc RC injectors bump a bit at idle.
Old 11-04-2009, 09:42 AM
  #25
camuman's Avatar
exactly, my rc650's will hiccup here and there at idle, and real low throttle situations. its not often, but it happens. if i had known of id725's, i would have done them.
Old 11-04-2009, 09:55 AM
  #26
camuman's Avatar
[media]http://www.youtube.com/watch?v=RX1xIvOWcNk [/media]
Old 11-04-2009, 01:08 PM
  #27
Spoolin's Avatar
Is that 90 psi of fuel pressure at full boost? Can you tell us what you have your idle fuel pressure set at?
Old 11-04-2009, 02:46 PM
  #28
deathsled's Avatar
4 1000cc injectors running e85 would be good for around 500 at the wheels.
On 93 they should make about 660 maxed out, so since e85 takes about 25-30% more volume than gas that brings you to around 500.
and wow that integra. That thing is idling rich as hell and definitely needs new motor mounts hahaha
Old 11-04-2009, 03:13 PM
  #29
Spoolin's Avatar
That would be true with the 1000cc injectors and e85 if you didn't have a twin fuel system. But with a twin fuel system, you can turn the fuel pressure way up to get a lot more out of the 1000's. 600 whp on e85 is very capable if you turn the fuel pressure up.
Old 11-04-2009, 04:33 PM
  #30
Banned
wadzii's Avatar
just to give you guys an idea on how much extra fuel e85 takes.. my S has an intake and aem ems.. on gas my injectors see max duty of ~70%, i switched to e85 last week, i hit 100% at 8700rpms.
not only does it take an extra 30% to make the same AFR at the same power, but max power (rich) is achieved at around .71 lambda for e85, while max power (rich) for gas (12.5:1 AFR) is .85 lambda.
so to get .85lambda with e85 it takes about 25-30% more fuel than with gas, but to get down to .71 lambda it takes another 14%.
that ends up being ALOT.
Quick Reply: ID 1000's and E85?
