ID 2000's & AEM
Old Aug 28, 2012 | 07:08 AM
siadam's Avatar
Default ID 2000's & AEM
Here is the graph as most of you have already seen.
In my AEM, v1.
It goes from 6-16. What values do you put in for 6,7,9,11,13,15 ?
It's been 3 yrs since I did my ID 1000's and I don't remember what I did.
Thanks,
-Adam
Old Aug 28, 2012 | 10:21 AM
siadam's Avatar
IIRC, I think I just subtracted column 10 from 8, and then 1/2 that amount to get column 9, and rinse/repeat for the rest.
Old Aug 28, 2012 | 11:07 AM
mase1's Avatar
Interpolate between the points
Old Aug 28, 2012 | 11:26 AM
herecomesboost's Avatar
Based on your equation, '9 volts' would have a dead time of '252.2' I believe what you meant to type: take the average between the two even numbers to reach the odd value (ie. (value10+value8)/2 = value9)
Old Aug 28, 2012 | 11:51 AM
siadam's Avatar
1540 (column 8) - 1020 (column 10) = 520.
520 / 2 = 260
1020 (column 10) + 260 = 1280 for Column 9
Old Aug 28, 2012 | 12:06 PM
sohc_mshue's Avatar
Hit the "calculate" function in AEM and it will automatically interpolate.
Old Aug 28, 2012 | 12:07 PM
520 / 2 = 260
Oh! You meant ADD 1/2 of difference between the two columns to the first column. Both equations reach the same value (my calculations were for base pressure (43.5psi))
((value8-value10)/2)+value10 = (value10+value8)/2
Old Aug 28, 2012 | 12:10 PM
siadam's Avatar
I've seen that on the fuel/timing tables, but not on the batt table, maybe I just "assumed" it wouldn't work the same. I'll check.
Old Aug 28, 2012 | 12:14 PM
siadam's Avatar
Nope your right. Live/learn.
Old Aug 28, 2012 | 12:21 PM
Cool
