ID 2000's & AEM
Old Aug 30, 2012 | 08:20 AM
siadam's Avatar
Ok, I've changed the batt offset table, but it looks like you have to rescale the fuel map as well to reflect those vaules. I selected the entire fuel map, and right clicked and then went to change fuel injector/pressure.
Anyone done this before?
It has 2 areas, for old injector/new inhjector and base pressure.
Old Aug 30, 2012 | 10:35 PM
siadam's Avatar
Bump.
Car fired up after the rescale, but won't stay running for more than a few seconds. I just don't have the time to dick with it (hence why it's september and Im just getting around to the car).
Anyone have a basemap, with ID 2000's I can use to test for leaks and pull on trailer for tune ?
Thanks on advance.
Sent from my iPhone 4 using Tapatalk.
Old Sep 4, 2012 | 06:50 AM
siadam's Avatar
Bump, hello?
Old Sep 4, 2012 | 11:26 AM
sohc_mshue's Avatar
Add fuel to the map until it stays running. Most likely too lean.
Old Sep 4, 2012 | 08:29 PM
siadam's Avatar
Cousin said same thing, I'm gonna review the map and see.
Old Sep 5, 2012 | 09:28 AM
goldsS2000's Avatar
I don't know how much of a hurry you're in to get a base map but I may be able to help you out. Is it possible to get the map off my ems with the car torn apart ie no electricity? I'll be at the shop in 2 or 3 hours man
Old Sep 5, 2012 | 10:53 AM
siadam's Avatar
I'd certainly appreciate that. You'd have to plug the aem into the car, and hook it up to a battery charger/tender and then turn the key on, download the map and your good.
pistolas s2000
Ηλεκτρικά Θέματα
Feb 15, 2014 12:16 AM
chillout18
Apr 18, 2013 04:40 AM
Christakis
Apr 3, 2013 12:11 AM
