IllestRolla's 03GPW Boost/Build * v2.0 2018 Updates*
#101
Thanks man , There was a stock one right behind us that I didn't get the chance to run, but after seeing those pulls he didn't want any
Trans seems to be holding up fine (for now)
Very hard to hear with the bike noise in the background, but hell yes I was brake boosting. I wouldn't stand a chance just rolling into it, this snail takes quite some time to get cookin'
#102
What rpm u change gears have u done head studs or springs/retainer yet? And ya man I want to bust my 1000 from 40 to120 on tires and race gas haha
Sent from my DROID RAZR using Tapatalk 2
#103
Yep, 100% stock top and bottom. I have AP2 retainers for over the winter.
Tires are Sh*t HTRzIII's
Speed based boost is your friend. The powerband is actually quite mild, even sitting on the brakes and unloading it still doesn't break free.
#108
Definitely just spent over an hour reading this entire thread. Sick build, learned alot, keep it updated! How is the Haltech as far as emissions inspection? Do you get to retain your OBD-II? I'm from MA, I'm sure NY is very similar.
#109
Thanks for the props man. Being that I used to teach auto @ a local career and tech center, I wanted to keep this thread as informational as possible, so thank you for that!
In regards to emissions, I will be removing the Haltech unit, MAP sensor, EGR blockoff, and injectors to pass inspection when the time comes. The haltech unit has no obd2 functionality. KPRO is the only choice if you are looking to retain that.
However, I do enjoy that fact that the Haltech still retains the CEL and I have the ability to pull diagnostic codes, just like a normal ECU.
#110
Update:
Was pokin' around under the hood over the weekend. The turbo screen looked a little "dark"
Took it off to find a compressor housing that has been slung with oil, and a decent amount of lateral shaft play
Not cool.
Not cool.
