Ingalls ETD modified for vortech supercharger.
Figure I’d post this here.
I modified my ingalls engine torque dampener to work with my newly installed vortech supercharger kit. Makes the blower a pain to install but I think it was worth it. I wish I took more pictures along the way.
This is the only other pic I have. Had to extend the bracket where the ETD connects and drill a hole through the bracket to allow the supercharger pulley to poke through. Might make another since I now have a template. The only downfall to the bracket is that the tensioner pulley gets pretty close to bracket where it mounts to the timing chain cover. Modifying the bracket to accommodate the pulley should be easy enough. In my case it wasn’t in the way so I left it as is.
Just so you know that this mod will only work with the vortech supercharger and not the sos or comptech kits. They utilize the bolt that’s used for the ETD In their own bracket system.
This is pretty good! Glad to see it fits. (Apologies for the thread bump by the way). I wonder if I could get the 'traditional' ETD designs to work with a modified Vortech VTEC sandwich plate... will post a pic of said modified bracket asap.
@Kyle thanks for pointing me in this direction
To the OP: is there any buzzing or undesirable clashes between the Ingalls bracket and the Vortech pulley/s at all? How's the driving experience with this ETD running in your boosted SC setup?
Glad to hear it gave you 0 issues. I need to upload a pic of an S2K with the modified Vortech bracket and show you. Perhaps an ETD could integrate with that bracket instead of the supplied Vortech one which is known to break eventually.
if you can come up with a modified bracket that integrates the timing chain cover bolt similar to the SOS and comptech kits that would be fantastic. Im confident that this bracket could then support the ETD stress as well. The only reason why my modified ingalls bracket works is due to the vortech not using the timing cover bolt. The weakness of the vortech kit for sure
