Inline pro PSI 3mm
What do you think is the most you should boost on a inline pro kit log with a 3mm hg. I am at 20 psi but many people run as high as 23 psi. Any thoughts. YA at Inline pro please chime in.
I was at 28-29 psi on the IP 3mm HG and boost was dropping to 25 psi at the top for a while before I pulled the head to have it built. I'll be pushing 27-28 psi on my new Precision 6262 turbo with the IP 3mm HG on e85 as soon as it warms up a bit.
wats the most psi u should run with the ip3mm headgasket, arp studs, rc750 injectors,walbro 255 fuel pump on a completly stock motor?........... would like 2 know the max psi b4 things start 2 break?.......... oh yeah completly stock rear end 2
That is all in the tuner Revenge.
The number of boost should never be the number to refer to as safe. Each turbo is different. Running a huge turbo on pump might be set at 15psi "safely" vs a smaller turbo 12psi or 18psi to be safe.
You can't set the boost number as your reference point.
My generally recommendation to most is 450-500 is max on PUMP GAS. Sky's the limit with race gas
Originally Posted by Spec_Ops2087,Jan 26 2010, 10:41 AM
I think it's pretty obvious that the max boost run should be whatever your TUNER think is right...
i think the max pump i have seen on a 3mm is 590 dynapack evans dyno.
soooo, that is the real answer, how much pump gas power can i run, 590 whp dynapack.
