JDMBLINDIAN's FULL BUILD THREAD CIVIC and S2000
#31
i bought my kit used and paired it with a garrett p-trim i got from Evans Tuning.
at first I didn't think I would want anything over 600, but now since I have to put all my stuff into a new car, i'm going to go ahead and see if I can't get into the 700's. (stopped at 450 on pump/93 octane the first time around)
i imagine you will make similar numbers to illestrolla, since yall have both have nice sidewinders and the same turbo. a good safe limit is 450whp. I imagine that you will be between 360-420, depending on how low that dyno reads. that would definitely be above 400 on a dynojet. The lag will probably suck after a while for you and illestrolla, since yall have such low goals and such huge turbos, but thats just my opinion, obviously.
#32
BUMP!!!!
Got the car tuned! It made 454 whp and 327lbs of torque on 14.5lbs of boost!!!! They did a test with a bigger filter and and it made 15 more whp. When I get adjusted to the car I will add that on. The car is SCARY! Oh it also sounds like a corvette with a BORLA exhaust. Will upload a Video saturday with the DYNO graph!
#35
#36
WIll do my friend I will as soon as I get home. I can't do it at work because the proxy blocks Photobucket
#37
It was on a mustang DYNO Btw I forgot to mention that lol. When the turbo hits it HITS HARD! at 8psi I made 350. The car would pop a lot so they had to gap my spark plugs!
