JMEARES's Turbo Build
Finally getting around to posting a build thread on my car that I have been working on for some time now. Here's a little info on the build, will try to get some pics up as well.
-Shortblock
Benson sleeved F20c block
CP 9:5:1 pistons w/upgraded wrist pins
BC 625+ H-beam rods
Micro polished crank
ACL race bearings
-Head
Kings Performance Race Spec Valvetrain
Port and polished
ARP headstuds (will be changing soon)
Inline Pro timing chain tensioner
F22 exhaust cam
-Fuel
Full Blown dual pump hanger
Twin AEM 320lph fuel pumps
Kings 2100cc Injectors
Full Blown fuel rail
Full Blown fuel regulator
Full Blown Inline fuel filter
-10an black braided feed line
-8an black braided return line
-Turbo set up
Full Race forward mount twinscroll manifold
BorgWarner S366
Tial MVS 38mm wastegates
Tial Q 50mm bov
Treadstone 1045 intercooler powder coated black
2 1/2" & 3" intercooler piping
-Other
Full shaved engine bay
Tucked wiring harness
4" custom exhaust
Full blown 3core half size radiator
Comp Twin Disc Clutch
AEM EMS V2
Hasport 70A motor mounts
Hallman pro boost controller
4 bar map sensor
-Shortblock
BC 625+ H-beam rods
ACL race bearings
-Head
Port and polished
F22 exhaust cam
-Fuel
-Turbo set up
BorgWarner S366
Tial Q 50mm bov
-Other
4" custom exhaust
AEM EMS V2
4 bar map sensor
The build started last winter when i bought the car fairly cheap with a blown motor with plans on building it to drag. HP goals for the car are around 800whp for this fall.
Tearing the stock block apart with a spun rod bearing.
Benson Sleeved F20 block from Kings Performance, stock bore.
Assembling the shortblock.
Mounted the stage 3 ported head thats equipped with kings race spec valve train. ARP headstuds are being used for this fall but will be switched out over the winter along with the rods to support a much higher hp goal.
Painted the stock intake mani and throttle body to match the block and my full blown accessories.
Full Race forward mount twinscroll mounted on.
Painted the block and other parts wrinkle black to match.
