JSchwieb's GT3582 Turbo Build - Page 2 - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Forced Induction
Reload this Page >
Notices
Old 10-15-2018, 06:18 PM
If you plan on running Pump Fuel + e85 you will need ID1300 injectors. ID1700's are for 600hp+ and on pump the idle will feel slightly lumpy.
MARK AUS S2K is offline
Old 10-15-2018, 06:23 PM
What do you mean pump fuel and e85? I will just be running e85, no pump.
JSchwieb is offline
Old 10-16-2018, 11:20 AM
s2000ellier's Avatar
flex fuel sensor, tune adjusts based on ethanol content
s2000ellier is offline
Old 10-16-2018, 11:33 AM
Ahhh okay, yeah I don't think I will be running that setup unless you guys absolutely recommend it.
JSchwieb is offline
Old 10-16-2018, 12:31 PM
Mijae007's Avatar
Its up to you. It'll allow you to fill up any amount of pump gas or e85 at any time. its convenient forsure. and the aem ems you plan on running will allow for a flex tune.
Mijae007 is offline
Old 10-17-2018, 08:49 AM
Update, just realized I will need to run water lines to my turbo and I don't have those. What lines do you guys recommend, also if I am not relocating my oil filter where should I pull the coolant from?
JSchwieb is offline
Old 10-17-2018, 01:31 PM
There is a hardline that goes across the front timing cover to a hose that ties into the oil cooler. You can tie into the cooling system there. A barb fitting would work but if you really want reliability have AN fittings welded on.
this is what I did no mine to prepare for water cooling the new turbo. Yours can be much simpler than this. I eliminated the cross pipe but you dont have to do that.
Charper732 is online now
Old 10-17-2018, 03:36 PM
another option is delete the oem oil cooler thing and run an external oil cooler which would free up the two water ports that supply the stock oem oil cooler. that is what i am doing.
Old 10-18-2018, 11:14 AM
Thanks everyone for the cooling options, lots of simple ideas that I didn't think about.
I have changed my build up a bit. Instead of a GT35r I will be running a GTX3071r Gen I, since I still would like to hit the 500whp mark I will be running a 1.06 AR Housing. Hopefully I will still be able to reach my goals while having a turbo that isn't too laggy with this setup!
JSchwieb is offline
Old 10-19-2018, 11:53 AM
Another update, just realized the brand new Tanabe Medalion Touring I installed and don't even have 20 miles on is too small for my HP goals. I originally bought this exhaust thinking I was going S/C....oops! Anyone know of any quiet 3" exhausts?
JSchwieb is offline
Quick Reply: JSchwieb's GT3582 Turbo Build
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
