Kraftwerks SC inbound, advice would be helpful.
#151
There is a new bracket on the exhaust side. It’s an extra extension that bolts onto the original style bracket. There is a pic of it somewhere in this thread. All new kits come with it. They also come with APR bolts for that exhaust side bracket. Not sure why they told you that.
#153
SOS wiring and 255 Pump today. Just got the trans back in with an ACT 11lb flywheel and FX300 with OEM bearings. Got to re-tighten/check it all over but I think Im days away now. Still cold in CO though so might be a few weeks. I also ordered a Kings Performance coolant overflow/catch can and bought a vibrant nipple for the PCV valve replacement. I am thinking ill T together the pcv valve replacement barb (below) with the breather line and run into the catch can, unless anyone has any strong opinions>?
Vibrant Performance 11416 Male 14mm x 1.5 Metric to 3/8" Barb Fitting
#154
SOS wiring and 255 Pump today. Just got the trans back in with an ACT 11lb flywheel and FX300 with OEM bearings. Got to re-tighten/check it all over but I think Im days away now. Still cold in CO though so might be a few weeks. I also ordered a Kings Performance coolant overflow/catch can and bought a vibrant nipple for the PCV valve replacement. I am thinking ill T together the pcv valve replacement barb (below) with the breather line and run into the catch can, unless anyone has any strong opinions>?Vibrant Performance 11416 Male 14mm x 1.5 Metric to 3/8" Barb Fitting
#156
i have a circuit hero that cleared with a very small amount of trimming of the bar... it wasnt so much the supercharger that was causing the issue more the piping off the intake due to the diameter, but like a said minor trimming and it fit.
#157
#159
Skunk2, Kraftwerks, Grams, whatever falls under the Group-A moniker....has absolutely horrendous customer service in terms of technical questions. Their warranty and returns process seems to be hit or miss at best, but I've emailed them and called them a couple times with questions about the kit and have gotten varying answers......The one that really gets me the most is the fact that they no longer offer the -91 blower, and instead offer the -92 as an "upgrade". Problem is the larger opening in the -92 requires a new elbow....one that KW hasn't bothered to make....so unless you fab a pipe you can't hook up your bypass valve or valve cover breather hose....I specifically told them I'd like to order the kit with a -91 as opposed to the -92 and they never got back to me and closed my help ticket. The people there clearly don't seem to know their own products well....I think they owe a few people in this thread a couple of cold ones for doing R&D for them.....There's obviously some interest in the kit, this thread has 19k+ views, plenty of people are running it and considering it, it's well priced, and can potentially can be a good kit if sorted properly....real shame they don't offer better support.
