krank vent installed, boost lowered by itself?!
As the title says, after my bitching about the krank vents taking a long time, they finally arrived and I installed them correctly ASAP (yes I have the popcornish bubbly noise too, sounds fun). Anyway, I noticed the car felt a little...how would you say, smooth during shifts and when part throttle to no throttle transitioning. Mostly that it doesn't backfire or have that gurgly sound to it that it used to.
Anyhow, I decided to do some logs with the EMS to see how things were doing, and I did 4 pulls, 2 in 3rd, 2 in 4th, to redline in each, at diff times of the day, all after the car was warmed up and driven a few miles, but not back to back, make sense? Prior to the krankvents, I was running consistent 20 psi all day long. Every single log that I did, the most psi seen by the EMS was 18.5, every time, without fail. I never touched the Inline Pro MBC or 'bumped' it or anything like that, it is double zip tied to a secure place where it can't be hit. I was wondering, is this normal? Has anyone else noticed this? Just out of curiosity, why do you suppose this happened?
Thanks.
Thanks.
Originally Posted by Dsgs2k3,Jul 12 2007, 12:37 AM
make sure there is no leaks and everything is tight first off.
if everything checks out, why dont u just turn up the boost controller a little
to make up for it
to make up for it
Remember, we're driving Honda's. It's supposed to be all about show and no go.
Originally Posted by Ustemuf,Jul 12 2007, 12:41 AM
test was done on the same day? temperature outside the same?
No shit I can just turn up the boost controller, my main question was why did this happen with the krank vents and if anyone has had a similiar experience.
Originally Posted by Soul Coughing,Jul 12 2007, 07:20 AM
do it again today, then take off the krankvents, and do some more logs... see if it actually changes
You guys are missing the point. I'm wondering if anyone else has experienced this and why krankvents would cause this? More vacuum somehow messing with the pressure of the MBC ball/spring?
Someone correct me if I'm wrong, but the purpose of KVs is to relieve the excess unburnt blowby gases out of the crankcase back into the intake pipe thereby increasing vacuum as a secondary effect. So it would in effect make sense that the KVs would lower your boost by a small margin, but then again, I could be wrong.
Do you feel any power loss from the lower boost reading?
