Comptech Supercharger in CA
I am looking to get one of these kits installed in my s2000.
I have the Ballade header and test pipe and I want to pull the trigger but only thing that is holding me back is I want to be making about 350 to wheels. The tech said he is able to run a little bit of a smaller pulley than the stock one that comes on the kit and said we can get near that number.
I'm just asking if that is possible since the stock kit on their site says 310-320 at the crank.
Help me out I really want to pull the trigger but want to make sure it is worth the money.
Yea but that would be another $2500. He is saying that with the stock injectors and just a little bit of a smaller pulley we can get around 350 wheel.
That's with a piggyback
Unless its an exceptionally high reading dyno, you wont see 350whp, but you will likely see 315-325whp dynojet. With the stock supplied pulley you typically see 280-300whp. 360cc stock injectors cant flow enough to make 350whp. That's about 400 engine.
Okay so we are running whatever Comptech is throwing in with the kit as far as Emanage or whatever piggyback they are giving with the kit.
I have an ap2 so I will be good running a 4'' pulley
I also have the stock clutch and it is working great for now. He said don't change it until it starts slipping im wondering how long it will last.
First things first, you might want to listen to Mr. Junky, he knows everything!
By the way I have an ap1 and making 281whp @6psi with the CT-E SC.
Upgrading your injectors with a smaller pulley will bring you close to 350whp, which is something I've been thinking about doing as well. I also thought about leaving the stock injectors and swapping for a smaller pulley, but the last thing I want to do is kill the F20. I say pull the trigger only IF you don't like the 280whp @6psi. Perhaps save up some $$$$ so you can upgrade the injectors when your ready to go with a smaller pulley. By the way, how is that Ballade header working out? I'm all stock, except for the bored out ITM & TB. In my opinion, stock header is all you need for the S2k.
One last thing Kerrp, I got all my work done at Autowave in Huntington Beach. You should call them and speak to Mike aka "Dyno Mike", that guy is a genius! Let him know Rafael referred you.
Good luck on your project and PLEASE KEEP US POSTED WITH NUMBERS, ISSUE, AND PROGRESS.
****Junky, do you know or have you heard if the Novi 1200 that comes with the CT-E SC can produce anything above 400whp????
It absolutely can. I ran a Novi 1220 at 420whp. The 1200 is far more capable than the 1220 at comparable PSI. There are tons of people with >400whp on the 1200.
Hey Guys!
I went over to the shop and he gave me a lot of information and I will be running a little bit of a smaller pulley as JUNKY said and will accommodate fuel.
He will be dyno tuning it as well with his "blackbox" that he supplies to SOS and other manufactures himself (this is the comptech kit).
Spaceman: the ballade header is worth it even without a tune it definitely shows some gains all through the power band. If I didn't have that header I would have the STOCK one because you are right it is VERY efficient.
I have one question is gas mileage?! What is going to be my mileage he said he will be able to adjust the A/F. But I still want decent gas mileage. Because my gas mileage right now is pretty great like 28 highway and 23-25avg.
