low idle oil pressure with greddy kit...
Hey guys I think I might have a problem
Greddy Kit with oil relocation and also using a greddy sandwich adapter (I know I'm stupid didn't see the extra oil temp until the adapter was on.
Cold oil temp (startup) is 85 PSI with a 75 degree ambient temp
the pressure seems fine on the highway everything normal except for my indle pressure
my idle is 900-1000 rpms and when the oil is 190 degrees my oil pressure at idle is 14-18 psi. This seems low. The oil is full etc. I need to talk to the shop that did the install and make sure they used 10w-30 and not 5w-30. Assuming they did what gives?
I'm using a SPA digital gauge with oil temp/pressure.
Any ideas?
Any ideas?
10w-30 is what is recommended for this engine; I don't see the problem?
Mine idles around 20psi unless its the dead of summer where it can dip as low as 12psi for a second or two.
hmmm....i just installed mine last weekend and have about 35-40psi at idle (70 degrees outside) and goes up to 85psi when driving.
My oil level is normal....and i'm running a vortech kit
I also noticed a slight 2-3 psi drop after the sandwitch adapter was used. I think I will take it off and just use one of the tap points on the oil recirculation kit.
I am doing my own oil change tomorrow, I have the oil (6QTS or so of 10w30 Mobil 1 Synthetic), but I bought a NAPA Gold Oil Filter...........I got home and thought to myself, (hy would you buy a NAPA oil filter), should I return it for a Mobil 1 Oil Filter, or even just a Honda OEM Oil Filter?
