Metallic slurry sound after cylinder head reassembly
Upgraded valvetrain and put everything back together and went to start the car and heard this metallic slurry sound. At first i thought it was a frozen pulley. I started the car without drivebelt, same sound. I did swap out oem to fluidampr pulley during the head upgrade so i will install oem pulley tmrw to see if that was somehow rubbing. Any ideas what might be the issue? I will undo cams and reinstall if the pulley checks out fine. Here is a video any help is appreciated headphone users beware:
Maybe the timing chain tensioner somehow got messed up during reassembly (had a hard time retracting it to reassemble it)aswell and is putting too much pressure on cam chain? |
I think you answered your own question. I was running a ballade and it failed on me. Would not retract enough and made some weird noises...albiet, not the same as yours. I put back in a modified OEM and problem solved
It probably could be a lot of things, but when I went from my Ballade to BillMan’s my motor sounded silky smooth and silent. Just saying. I heard Ballade stuff might have been reformulated by now, so depends on how old it is. I did see the damage on one part of the Ballade TCT that could cause complete failure, it was a groove that was jus started to develop on one of the TCT parts but I don’t recall exact part name. |
I had the ballade TCT for a year with no issues. Problem was when i took it out and back in basically it was difficult to make the worm gear rotate back into place via screwing in the 5mm(i think)bolt and wingnut. I removed it and just ordered an oem TCT and will eventually get a billman TCT when that starts to fail... Will report back if that fixes the engine whine.
Originally Posted by F1TwoThousand
(Post 24573550)
Originally Posted by Charper732
(Post 24573659)
Drill the oil feed on the OEM TCT a few sizes bigger and you won't have an issue with it failing
Installed new oem tct same problem. Will be reinstalling cams
