Motor went down tuning last night, trying to decide what happened, pics inside
Old 05-27-2014, 04:18 AM
Banned
wadzii's Avatar
were all the cylinders melted like that?
Prolonged detonation can lead to pre-ignition, its kind of hard to say for sure, but if its only one cylinder melted that bad I'd make sure you dont have an injector issue.
The aem base cal for s2000 has about 24-25deg at WOT, if you pull 1 deg per/lb you'd end up with 12ish deg of timing at 12 psi
Old 05-27-2014, 12:26 PM
d-bo's Avatar
way too much timing
you're also loading it up a lot in 4th opposed to 2nd gear. prob should have backed it off a bit after finishing your 2nd gear pulls
anything on not E85 i would use an EGT gauge.
my car had mid to high 20s at WOT ~ 14lbs and it blew apart the motor. i found myself a new tuner. i would suggest doing the same.
Old 06-01-2014, 03:59 PM
pettyboy69's Avatar
2 pistons have holes, the other 2 are pitted so I'm sure it's not the injectors cuz I was wondering he same thing, I'm in agreement with everyone on too much timing
Thanks for all the replys!
jbotstein1
09-10-2006 05:17 PM
Humanatek
04-14-2003 01:28 PM
Milo
04-18-2002 03:18 PM
ChrisD
01-11-2002 01:31 PM
Quick Reply: Motor went down tuning last night, trying to decide what happened, pics inside
