My car wont start.
Hey everyone so I just got done installing a custom turbo kit on my car and when I went to start it up it wont start. I am using the emanage ultimate and when I turn the ignition I can hear the fuel pump prime the lines but I dont know if my injectors are working. The car cranks but it just doesnt start like its not getting either fuel or spark. On my injectors I pulled the blue piece out and just stuck them on there I'm not sure if thats my problem or not so any suggestiosn would be great. Thanks
have you actually checked to see if your getting fuel or spark to the plugs?
pull the plugs and smell them to see if you are getting fuel
then connect the plug to the coil, and see if you get spark
if you arent, check connections etc... if you are, check your injector sizing with the software
ok I will try and go look at it today and check those 2 things and see which one isnt working. Yes by blue things I mean the blue piece in the injector clip that you can take out and make it fit on the injectors.
So I took the spark plug out and hooked it to the coil and tried to start it and it didnt spark, I'm not really to sure what that means or what to look for so any suggestions would be great. I haven't checked the injectors yet I figure one issue at a time.
Oh and also when I tried to start it without the spark plug in some coolant came out of the hole dont know if thats bad or not it only happened the first time I tried to start it not any of the other times.
