Originally Posted by liquidgsr
(Post 21396033)
I wonder if I send them my manifold if they can make the cover for it then just make you another so you can put it on yours.
I'm thinking of making a large one piece heat shield for the heater valve and battery + fuse box, then lay some gold foil on it to protect more. Would think that could work? Thinking of this: http://www.full-race.com/store/therm...tive-film.html Edit: Btw, the manifold and turbo is HPC coated. That should also help at least a bit.. |
Sure I will let you know when I send mine in. They said it would be 414 for my manifold. I guess the person who had it got it black Coated but some of it is coming off. The heat shield foil idea is a good one.
Also look into heat shielding for your engine mount or create a shield and get a turbo blanket you'll melt the engine mount eventually also
I thought Sarek sent his fullrace mani to ATP, so they should already have a template??
They said each one is custom so I need to send in the manifold and exhaust housing of the turbo. Im planning to go with a gt35r .82 a/r.
In for this. :thumbup:
Dynosheet pleaaaase? :)
1 Attachment(s)
great installation! your tune might benefit from an earlier VTEC switchover point?
Nice build man :tipwink:
