New to boost question?
Im almost done installing my supercharger kit, as well i have 1000cc injectors, and a walbro 255 pump. While im waiting for my base map from my tuner ( on aem ems), could i start the car with the stock ecu. I would like to check for leaks, belt tension, make sure everything works, etc...
Probably easier to swap back in the stock injectors to check for leaks.
Hell no the car is not going to start or run with the stock ecu and 1000cc injectors. For what your trying to do you need to make sure you install the stock injectors and make sure you have the stock map sensor in so you can start the car on the stock ecu to check for leaks.
Did you have any negative effects to the car after starting? Because i want to
