New Kraftwerks kit possibly fitting with SOS V-Mount?
#22
Well I was able to install the sos vmount. I did have to make a few mounts so I cut the tabs down low so I could move the intercooler lower. It gave me room for a cold air kit. After I was done I have 16psi at 8500rpm and coolant has not gone over 200f and that was thrashing the car. Flat out in straits and pulling alot of gs in corners. I also build a flat bottom built my diff myself added a kick out oil pan to the back. I used a marine self priming pump. It holds 3.5 qts of oil with a 19 row setrab. I had to do this because without it the diff would get hotter and hotter the more you push. Had to stop and let it cool as I saw 260f. With the cooler it's not gone past 210f. That is tapping out 6th gear in 100f Temps. The downforce with 450whp has burnt up my act hdss clutch. Areo is like religion or a trust fall. It is scary at first but then it's addictive.
