No O2 Sensors to Stock ECU - S2KI Honda S2000 Forums
Notices
Old 03-12-2019, 06:15 AM
Default No O2 Sensors to Stock ECU
I have a supercharged AP1 that I need to get tuned on aftermarket EMS. I have the pre and post cat factory O2 sensors disconnected and harnesses taped up. The only sensor is the aftermarket wideband mounted in my header.
I plan to swap back to factory injectors and ECU to drive to the shop with supercharger belt disconnected. Can I leave the factory O2 sensors as they are (disconnected) and drive to the shop? Will it just run very rich and throw a CEL?
s2kvince is offline
Old 03-12-2019, 07:07 AM
EOE
EOE's Avatar
or very lean and melt your piston.
Jokes aside, not 100% sure how OEM would react or go into limp mode, but I wouldn't as it wouldn't be able to control short trims under light load to keep your AFR in a safe zone.
EOE is offline
Old 03-12-2019, 08:05 AM
I figured it would just run in open loop mode like it does upon start-up when the O2 sensors are not warmed up. Looking for the easiest/safest way to get this car to the shop in the current configuration while trying to avoid a $150-$200 flatbed tow, if not necessary.
s2kvince is offline
Old 03-12-2019, 11:11 AM
s2000Junky's Avatar
Keep the factory upstream sensor in place on header. The one for the cat doesn't need to be there. 5 min swap at the dyno.
s2000Junky is offline
Old 03-12-2019, 01:10 PM
Mijae007's Avatar
just keep it under 3k rpm you should be fine.
Mijae007 is offline
RedSunS2K
09-18-2012 02:00 PM
Spec_Ops2087
25
02-15-2012 11:56 AM
o'malley_808
03-29-2008 08:51 PM
MB
10-03-2005 11:11 AM
02spas2k
11-03-2003 09:17 AM
Quick Reply: No O2 Sensors to Stock ECU
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
