No spark... help!
Old Oct 29, 2009 | 10:11 PM
EK9MAX's Avatar
Default No spark... help!
Ok so i'm not getting any spark....
Did the ol' screw driver in the coil trick and i'm not getting any spark....
What are some things to check for?
I was having issues with my turbo setup running...
So I tried putting the stock injectors, map, ecu back in to see if that starts.....
Old Oct 30, 2009 | 01:24 AM
misz's Avatar
Cam timing or check the ground behind the head.
Old Oct 30, 2009 | 08:18 AM
EK9MAX's Avatar
checked both....
Cam timing would stop spark?
Old Oct 30, 2009 | 09:45 AM
Slows2k's Avatar
Stock PCM cars will not run with a camshaft out of time.
Old Oct 30, 2009 | 10:46 AM
spectacle's Avatar
There's a ground on the head? Pic?
Old Oct 30, 2009 | 11:53 AM
Slows2k's Avatar
The only way your gonna get a clear pic is to remove the head or trans. You can barely see the ground bolt when the engine is in the car.
Old Oct 30, 2009 | 05:39 PM
Envied's Avatar
This might sound stupid but start where you know you have swapped something out.. It could be possible that you cut into an injector clip wire and are having a short to ground because of it.. I had this happen once. Any short to ground can possibly prevent you from having ignition.
Old Oct 30, 2009 | 06:49 PM
EK9MAX's Avatar
I tried stock pcm, aem v1 and v2.
EK9MAX's Avatar
I changed out the whole engine harness to eliminate the possiblity of this.
Old Oct 30, 2009 | 08:19 PM
s2kmendez's Avatar
If you don't have spark and have access to a scanner first check for codes and if you don't have codes check the data display while cranking the engine you should see RPM signal if no signal check your crankshaft sensor that sends the signal to the PCM to trigger the coils and the camshaft sensor is used by the PCM to syncronize the injectors after checking all the grounds and connectors that should be you next step
