No way did he just ask that question AGAIN!
Originally Posted by Slows2k,Jul 3 2005, 01:02 AM
No, a VAFC is not necessary. It's another argument how effective a tuning device it is.
After thinking about my other question, regarding the need to reprogram after every change in boost level, I've realized that there is an aspect to all this that I don't understand at all.
All three of the kits I'm considering, Vortech, Comptech, and Lovefab, produce around 7PSI boost, but only the Lovefab requires a standalone ECU. The torque curves I've seen seem to indicate that the Lovefab produces much more boost at lower revs, but peak boost is about the same. Anyway, why does the Lovefab require a custom programmed ECU while the others don't?
Obviously, the simple answer is that there are limits to what the ECU can accommodate, but I'm looking for a more specific answer. Which of the limits of the stock ECU does the Lovefab exceed, and why?
Originally Posted by Silver S2k4,Jul 3 2005, 05:11 PM
Maybe in a 00-03 it would help but as for me having an 04 I would def not get gears because the revs go super quick as it is, I can't imagine making then shorter. You would have to shift from 1-2 in like .5 seconds, and 2-3 in like 1 second and so on. If anything with a FI setup i would get longer gears like you would have in lets say an Integra LS trans that a lot of people use on turbo B series motors because it has very long gears and once you start seeing boost then it just keeps going and going.........
Ofcoarse I am no expert in this and know a little more about the B series motors and trans than the F20/F22 but if you think about it, it makes sence.
In an NA car gears are THE BEST mod you can do, in a turbo/SC car I would never do it. Too much shifting would actually cause you to lose the speed and momentum.
) he would leave me at first, but I would start to catch up with him after 3rd gear...
Originally Posted by RED MX5,Jul 3 2005, 05:23 PM
I've seen those arguments, but haven't paid them too much attention, because the piggyback approach doesn't appeal to me. If I do end up having to tune electronically I'd rather just spend a little more and get a good standalone ECU (probably AEM).
gears & Nitrous. 4.57's w/ 75shot, If done properly you are looking at 1500 in Nitrous parts, 1399 in gears and enough money left over to take your woman on vacation.
If done properly and driven correctly, you should be good to go and capable of running with high 12 second cars on the freeway. Since you are not worried about launching, you should have no issues.
The beauty of Nitrous is it is not constant. I use it three or four times a month when I'm running with someone I know is faster.
Originally Posted by VeilsideAP1,Jul 3 2005, 08:36 PM
reason being is that the comptech and vortech units come with a little computer you wire into the harness of the ecu.
Vortech uses a MAP clamp, and a seperate Timing controller. The Controller is supplied to Vortech by Split Second. www.splitsec.com
None of these units supply the extra fuel needed in boost. That is accomplished by the FMU's of each kit. A FMU is a rising rate fuel pressure regulator. It increases fuel pressure drastically to the injectors. The Stock PCM still "thinks" the car is NA.
The Comptech FMU has as static pressure adjustment. I don't know of any rate calibration "kit" available for the Comptech.
Vortech's FMU is a Fixed rate not adjustable unit. The Rate is 10:1 for every 1psi of boost, the FMU increases fuel pressure 10psi, over static.
Any FMU installed will increase static pressure over stock, due to the increased restriction in the return line.
The stock PCM was never designed to see 7 psi from 3k rpm all the way to 9k. The fuel tables for a NA engine are totally different from what a turbo car needs. Lovefab is using 650cc injectors I believe. That's almost 2x larger than stock. An emanage can't compensate for over 550cc
A centifugal SC has a pretty linear boost curve. The faster the SC is spining, the more boost it's making. This allows you to get away with using a FMU for additional fuel. A turbo making 7 psi at 3K will have a delay from when boost is instantly applied to a FMU. This causes a delay additional fueling, the engine will spike lean, then go rich whe the FMU catches up.
The EMS offers full control over all engine parameters, something no piggyback controller can do.
quickshifting
Aug 23, 2007 11:17 AM
