Operating Temp
Old Aug 5, 2012 | 05:15 AM
  #21
f22cjh4's Avatar
Brought it back to Evan's Tuning, let them install the coolant lines to the turbo and asked them to bleed it for me. So far no problems since, with or withour AC
Old Aug 5, 2012 | 05:30 AM
  #22
camuman's Avatar
Good to hear.
Old Aug 6, 2012 | 12:02 AM
  #23
jjjimene's Avatar
Originally Posted by teamvalorracing
intercooler blocking the airflow to the radiator.
I do believe this is one of the main problems, i live in an area where temps are at 110 to 115 in the shade, in other words its extreme heat, and i was having those same issues. I couldn't drive the car if temps outside where more than 95
I just added a corvette Air dam, between the inter cooler and the radiator,and problem solve.
Now all the air that the inter cooler was blocking now it is being scooped from the bottom
Outside temps are at 112 now, my water temps are from 194 to 199, with the AC on.
Old Aug 6, 2012 | 05:26 AM
  #24
spectacle's Avatar
For everyone relying on the gauge cluster for temp readings - the ranges on the cluster are not precise and don't give an accurate representation of what's high or low when it comes to overheating. If you're in this forum, you should be looking at the readings on your EMS, either through live readings or logs, to see what your real temps are.
For comparison's sake, here's what you're seeing. Refer to the pics on the left
AP1 -
AP2 -
Old Aug 26, 2012 | 09:35 AM
  #25
f22cjh4's Avatar
COrrection the A/C worked for a while w/o the car oveheating, but eventually it started back up again. I think at this point I really need to get an aftermarket oil cooler and maybe upgraded radiator. I know Evans Tuning is suppose to be coming out with their kit soon. Then may I can have the A/C on in my car
Old Aug 26, 2012 | 09:48 AM
  #26
illestrolla's Avatar
Originally Posted by japhethwar
Running recirculate doesn't have a thing to do with the engine temp. All it does is close a little plastic door under the dash. Doesn't have a damn thing to do with the underhood, engine, or coolant temps. Your fans aren't doing the job. I've sat in traffic for an hour with the AC on blast in hundred degree South Carolina heat and the guage never moved. Thats with stock radiator and fans. Rebleed the system and get your fans working properly, problem solved.
Not entirely true.
The entire AC system has to work MUCH harder when you aren't re-circulating the air.
You are correct that all it does it close the flap under the dash, however it is much easier to heat soak your condenser working the system at full tilt always fully cooling the air, rather than re-circulating already cooled air.
A heat exchanger is a heat exchanger any way you look at it.
Old Aug 27, 2012 | 09:58 AM
  #27
Reapur's Avatar
Wait you were running a water cooled turbo without the water lines connected?
ktmpixie
Dec 23, 2010 12:52 AM
Spec_Ops2087
Apr 28, 2010 04:18 PM
josserman
Mar 29, 2010 06:02 PM
Silver S2k4
Feb 21, 2008 01:14 PM
nMeOnE
Oct 9, 2007 06:35 PM
