Pfab Stage 2 build
So, i decided to pull my Kit from the classifieds and install it, or at least start the process.
i still need a few parts fabbed up, which is being taken care of by my shop, the rest of the work i am doing in my garage with help of my friends. Specs: inline pro 9.1 CR motor Pfab ELT manifold GT35R competition clutch Tial q bov Tial 44mm wastegate ID 1000's in tank walbro http://i1238.photobucket.com/albums/...g?t=1295658357 still not 100% on my fuel set up and if my single in tank will be enough. not looking for big numbers. but would like to be around 500whp+/- more pics will be up soon |
Looks great, good luck with the install.
Thanks,
this is my first turbo install and it is going pretty well. thanks to my buddy smaggs. i hope to have it running mid march as i am in no rush, considering its always raining or snowing here right now |
Nice setup! I am in the process of the same setup except with a precision 6262. Check my build page if you need help relocating the fuse box and battery and wire tuck info.
Your fuel setup is good for your goal of 500whp. I have the exact same fuel setup. |
Your fuel setup is good for your goal of 500whp. I have the exact same fuel setup. the fuse box and battery are the next project when i have time. and thanks, i figured i would be good with my fuel set up, just wanted to make sure |
