S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   PISTONS (https://www.s2ki.com/forums/s2000-forced-induction-142/pistons-546461/)
Yels2000 Nov 28, 2007 03:49 PM
PISTONS
I've been searching this for about an hour and coming up with to much info but no answers :eek3:
What I found was either Wiseco pistons or JE pistons.
Wiseco has different sizes and I need to sleeve my engine so should I just go 20 over with the 8.8 CR or keep it standard with 8.8 or what? What does going 20 over give your engine?
JE pistons were 9 CR and thats about what I should have with my thicker headgasket. I don't want to lose any power. Would a .2 CR make a big difference?
Thanks...
brainwo Nov 28, 2007 05:05 PM
Most aftermarket piston for F20/F22 will not work with FRM Sleeves.
I think only TODA made piston for our engine that doesn't required to resleeves.
Yels2000 Nov 29, 2007 03:21 AM
I'm getting Darton sleeves.
Peter@ISP Nov 29, 2007 06:32 AM
im running cp pistons
Sideways Nov 29, 2007 06:39 AM
:thumbup:
Yels2000 Nov 29, 2007 08:23 AM
ok but is it worth going 20 over and since I'm getting it sleeved?
Peter@ISP Nov 29, 2007 09:30 AM
you can buy stock bore pistons from cp. i didnt go 20 over just incase i have to build the motor again
PeanutButter Nov 29, 2007 09:31 AM
Yes it is worth it, more displacement.
timg Nov 29, 2007 07:30 PM
I have stock bore pistons from Arias. They're 9.5:1 compression ratio. I'm running the stock bore because I wanted more wall thickness between the cylinders due to the turbo and the ability to bore out the sleeves later if necessary.
Tim
Yels2000 Nov 30, 2007 05:25 AM
OK thanks for your input,
One last question though,
How much horsepower will I lose going from a 9:1 compression to 8.8:1?
Thanks
© 2026 MH Sub I, LLC dba Internet Brands
