Planning my turbo set up
***Update 10/19/19***
Folks, Thank you all for the input. Real talk: this is a really cool and chill forum; way better than other car forums I've been on. The troll to supportive person ratio is heavily skewed toward supportive people. In late August, I ordered the PTuning kit w/ GTX3076. People seem to report the best results from this kit, compared to Fullblown, SoS, FullRace, etc. Only bad thing is I'm just waiting for them to make the next batch. I'm paid up but PTuning is still waiting for 2+- people before they start to build. Hopefully in the next few weeks. I'm sticking with Hondata KPro for the same reasons I stated below. If anyone has any experiences with KPro and inspection, I'd love to hear from you (PM me); I know it's probably a bit "taboo" or perhaps against the rules to discuss these things publicly. I'm also eyeing the SoS map sensor to pair with the Hondata. Anyone have any experience with this? Clutch will be ACT PP and OEM disk. Probably going to grab an AP1 flywheel too (AP1 slave to go with it). Taking all your advice with fuel: ID1000s + walbro 255 Gauges: I'll have the AEM wideband and I'll do a dual Innovate gauge or Spa gauge for Boost/Oil pressure. That wraps it up mostly. I'll update when the kit arrives and install gets going. ***Original Post*** Hey everyone, I've done a lot of searching and reading a lot about what may be best for my upcoming set up. The (unofficial) consensus across the forum seems to be the PTuning kit is top-notch. Another viable option is SoS. I have a 2005 S2K and my goals are not exceptionally high. I want significant power gains without requiring bottom-end work - if I had to put a HP number, I'd say I'm aiming for high 300s/low 400s on 93 octane (no e85 in my plans). I'm planning on buying by the end of this season, at the latest. Here's what I'm thinking and I'd love some input from you all:
I know you spilled a bunch of info above, and I'm not discrediting that effort. However, with your power goals, is there any particular reason you're not considering one of the available Supercharger kits? For your power goals, it would be cheaper, simpler, and more reliable, while also being easier on your drivetrain, and having no issues reaching your power goals.
Just some food for thought. |
Originally Posted by illestrolla
(Post 24589118)
Just some food for thought. I'm not averse to making more power than what I posted, I just don't want to run e85 or bottom end work, so this seemed like the best compromise from what i've seen folks on the forum say. Thanks for making the suggestion. Appreciate the input |
You should get ID1000 injectors. Not 650cc which I assume are RC. 650cc is too small and ID will run better even in the larger cc.
The 325 will hold your trq you will make at the hp goal you stated, but you get much past this and your better off just going with the 400, or the common ACT PP/OEM friction disc combo. In a nutshell, PT will make more top end but have more lag. SOS will give you likely better flatter trq curve and quicker spool. Depends what you want. If your already replacing the clutch and have a ap2 then yes for sure get a lightweight flywheel, either throw in the 14lb from a ap1 or get a SOS 8.5lb which is what I prefer. |
Originally Posted by s2000Junky
(Post 24589191)
The 325 will hold your trq you will make at the hp goal you stated, but you get much past this and your better off just going with the 400, or the common ACT PP/OEM friction disc combo. In a nutshell, PT will make more top end but have more lag. SOS will give you likely better flatter trq curve and quicker spool. Depends what you want. If your already replacing the clutch and have a ap2 then yes for sure get a lightweight flywheel, either throw in the 14lb from a ap1 or get a SOS 8.5lb which is what I prefer. SOS sounds more like what I'm looking Really appreciate the feedback my friend. Thank you. Any thoughts on whether I'll have any issues with temps/cooling, or do you think I'll be good with stock everything? |
Originally Posted by S2KLINY
(Post 24589196)
Thanks so much! Very helpful.
SOS sounds more like what I'm looking Really appreciate the feedback my friend. Thank you. Any thoughts on whether I'll have any issues with temps/cooling, or do you think I'll be good with stock everything? Under hood heat can be an issue with turbos on this car. The two scenarios where you will want to consider upgrading the cooling system is if you either plan on tracking the car, or find yourself in stop and go traffic in the middle of the summer with your A/C running. A vented hood and a larger Radiator are the easiest 2 things that can be done to address. Monitor it, if you find its an issue, its not hard to address it post turbo install. |
(Post 24589247)
No problem.
:thumbup:
(Post 24589277)
Very helpful, thank you!
In my opinion, the AP1 flywheel is a must-do upgrade if you're already in there to change out the clutch. It just makes the car more enjoyable to drive because the engine is more responsive.
https://motoiq.com/project-s2000-mak...-drivetrain/2/ As for cooling, if it's a pure street car, you likely will not have to worry about oil temps. A Koyo radiator is a good upgrade and probably a good idea to do regardless due to the age of the car. The plastic headers on stock OEM radiators are usually on borrowed time after ten years are will crack at some point. |
Makes sense and doesn't cost too much.
Thanks for the input. Appreciate all the feedback from folks on the forum. |
