Please help with fuel system s85
hello everyone I currently have a ap1 and I want to add a e85 setup to it. Made about 430 on 93.
car currently has Precision 6262 AEM V2 1000cc FBM 340 AEM fuel rail AEM regulator NGK 2668 now my question is I want to safely run up to 600whp, 1. Do I need a flex fuel sensor with AEM v2? I would like to add E and 93 whenever I want to and have it adjust automatically. 2. Should I go 1300cc or higher, I would like to keep drivability close to OEM when i run 93. 3. Do I need to upgrade to a Walbro 450? 4. What kind of fuel lines and feeds should I run? thanks for the help, please chime in any extra I may have missed. |
E85 Flex fuel sensor kit from SOS.
ID1300X injectors. Fuel pump bigger than the 255 walbro Your welcome! But definitely get the E85 flex fuel sensor kit first. Get it running/working then upgrade piece by piece dont do it all at once especially if your not familiar with all this stuff. Absolutely no reason to touch fuel lines btw. |
Originally Posted by F1TwoThousand
(Post 24501513)
ID1300X injectors. 255 walbro fuel pump or higher. Your welcome! But definitely get the E85 flex fuel sensor kit first. Get it running/working then upgrade piece by piece dont do it all at once especially if your not familiar with all this stuff. Absolutely no reason to touch fuel lines btw. walbro 255 or higher, i have a 340 now from FBM, would I be ok |
600hp on e85 with 1300cc injectors is pushing it. Would need a high base pressure or an aggressive tune.
First time ive ever heard of a walbro 255 making 600hp.. |
255 will not make 600 on e85 LOL
get a 450... 1300s CAN make 6... but its gonna be some high fuel pressure, and could max the pump out fairly quickly. 1300s be best drive ability though. once you move to 1650-2200s getting into some large injectors. you don't HAVE to run a sensor, but it helps with consistency. lmk if you need some retune help :D |
Im selling my walbro 450 AND ID1300 injectors...can sell fuel hanger with 450 already mounted, if needed. Lmk if youre interested.
Originally Posted by AP1Chief
(Post 24501605)
Originally Posted by Charper732
(Post 24501625)
text me 718-407-9835 |
Yes you need a flex fuel sensor and a flex fuel tune so you can be able to pump in E85 and pump gas and the eco will automatically up the boost and timing with higher percentages of eathonol in the tank. I recommend the science of speed flex fuel sensor kit. Yes you you should up grade to id1300cc injectors. They will max out about about the 600whp level on E85. You will probably have to run a base fuel pressure of about 60psi. The id1300 is the biggest injector you can go for stock like drivability on normal 91/93 octane pump fuel. The bigger 1700 and 2000cc injectors you will start to hurt and sacrifice drivability especially on pump gas. yes you need to up grade to a Walbro 450 pump and you need to reward it. I recommend the sos fuel pump wiring kit. Stock fuel lines will be fine with E85 and a 600whp goal. |
Anyone running or knows of a e85 brushless fuel pump? Im looking for the quietest fuel pump for 600whp using ID1300x injectors
