Post up your Flex fuel set up
#41
#42
#43
Heres a pic of my bay, same catch can
Attachment 73772
im already on e85. Aem 320 e85 pump, dw1300 inj, aem fuel rail and aem fpr, with oem return line back to the tank. How come you didnt run the feed from the oem port on the fuel pump housing? Did you just cap off the original port?
Attachment 73772
#44
Ap1
Here are a few pics of my setup, you’ll see the FF sensor, pressure sensor, temperature sensor (tapped into the aftercooler), and 3-bar sensor. Car runs great, only issue is at times, the car shuts off when pulling out of gear coming to a stop. Rpms drop very low to the point the car shuts off, doesn’t happen when I shift out of gear at high rpms...not a clue in the world why it’s happening.
Ill be swapping things back soon for smog test, I’m in So Cal.
