Post up your Flex fuel set up
Old 01-20-2018, 08:15 AM
  #41
hatrickstu's Avatar
Originally Posted by sirbikealot7
Agreed.
I'm running the SOS kit, I've got no aversion to fabrication and building hoses, but its a simple off the shelf package that works well for a reasonable price.
That looks great man! Some serious time on the turbo inlet!
Old 01-20-2018, 08:53 AM
  #42
sirbikealot7's Avatar
Thank you! Yeah I requested keeping the intake 4" through the entire length and getting the filter in front of the heat exchangers. Gabe @ Rampage Fabrication and Design is a wizard!
Old 04-17-2019, 09:51 AM
  #43
S2kMano's Avatar
Originally Posted by Mijae007
Heres a pic of my bay, same catch can
Attachment 73772
im already on e85. Aem 320 e85 pump, dw1300 inj, aem fuel rail and aem fpr, with oem return line back to the tank. How come you didnt run the feed from the oem port on the fuel pump housing? Did you just cap off the original port?
How much boost were running on this fuel set up?
Old 04-16-2020, 11:03 AM
  #44
Spaceman2345's Avatar
Default Ap1
Here are a few pics of my setup, you’ll see the FF sensor, pressure sensor, temperature sensor (tapped into the aftercooler), and 3-bar sensor. Car runs great, only issue is at times, the car shuts off when pulling out of gear coming to a stop. Rpms drop very low to the point the car shuts off, doesn’t happen when I shift out of gear at high rpms...not a clue in the world why it’s happening.
Ill be swapping things back soon for smog test, I’m in So Cal.
AlpineFD
12-22-2017 12:07 PM
Charper732
04-19-2017 07:55 PM
O85o678777
07-01-2011 11:58 AM
BrandonS
02-02-2007 11:26 AM
vtidan
12-10-2005 01:58 AM
Quick Reply: Post up your Flex fuel set up
