questions for supercharged guys 350-400whp running 285+ tires in the rear
#31
I am tempted to install the hondata traction control system something about hammering the s in rain and it just pop and hiss till it grips without having to pedal the car is interesting but for the money I could have a bad ass adjustable front sway bar if I was turbo it might be more enticing but that is why I choose supercharging over turbo so I could have a fast and fun car that doesn't try to kill me on every apex.
#32
Yep, like I said, providing its dry. No issue at all with traction
Yes but you are turbocharged? Completely different powerband to an S/C. Your torque comes on at 3-4krpm wheras S/c is more like 6-7krpm.
#33
I run standard sizes 215/245 Yoko AD08R's and like that you can spin first and are on the limit in second gear.
For me the S isn't about 60fts or first gear pulls. It's about driving on the limit. Having the car move around abit does it for me!
#34
It does help save the trans and diff as well. However in the grand scheme of things, if you are building the ultimate canyon carver/road course machine, more rubber on the ground improves lateral adhesion and stability helping to plant an otherwise nervous handling car, this is more evident at 60mph+. Having 400whp and stock size tires no mater how good the compound is has limitations, just form a sure footprint. Wider tires also run cooler, which can be good if your driving the car hard, not as good if your putting around on the street.
#35
i am supercharged 460whps.
n I am currently running 18 x 265. I will go 2.75 or 285 next time.after tire wears out.
#36
255's didn't save my comptech diff with J's racing pinion collar. It let go a few days ago ring gear failure. So I have a puddymod stage 4 with 3.63 gears and a carbotec LSD that will be going in once I get it back from Ben.
jon604
04-16-2010 11:27 AM
