Quick Question
When would I need to purchase a 3-Bar Map Sensor? Also, I just purchased a resistor box and that was for my 1000cc RC Injectors is there anything else I need?
James D. |
I think when you go above 9 psi.
THANKS!
11psi |
hehe, if your going to be using a system that needs 1k injectors, I should HOPE you would have a new map sensor :D
but FWIW, I ran ~10psi (creeped a little further maybe 11-12psi at high rpm) on stock mapsensor without a problem so I'm asusming it craps out 13-15psi or so but regardless, considering how cheap the 3-bar sensor is, its worth just upgrading it :) |
I think the stock map sensor is good to 10.1-10.2 pounds.
i was at 10.8 with stock sensor
place to find a 3 bar upgrade?????
Inlinepro!
Thanks guys good to know!
James D. |
| All times are GMT -8. The time now is 07:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
