Really loud NOVI 1000 blower
Hey guys,
Had my car dynoed over the weekend. The blower itself has a bad rattling sound coming from the housing.
Before the boost upgrade and the newly built motor, there was a little bit of a rattle present (gear lash?).
After the smaller pulley went on, the noise has gotten worse. It sounds like a spray paint can when you shake it up.
The blower still put out 13 psi, and the car put down 350rwhp/220tq... Which was limited we believe due to the Walbro not flowing enough fuel.
Anyways, back on topic.
I am considering ordering a rebuild kit from supercharger rebuilds dot com...
They have two to choose from:
Price: $250 (ABEC-5, thrust, 47K RPM), $400 (ABEC-7, thrust, 57K RPM)
Anyone know which I need?
Thanks a lot,
Matt
Thanks a lot,
Matt
the rattling sound like shaking a can of spraypaint is normal...maybe you're not describing it accurately enough? you should get a local supercharger owner to come out and listen and see what they think before you put out the money for a rebuild.
I experienced the same sound. I loosened the belt just a LITTLE, and the noise went away.
By the way, there was a post on here this past winter about a guy who rebuilt his blower CHEAP. He claimed all the bearings and seals are common, could be bought at your local hardware store.
I think he also stated that PAXTON will rebuild the blower for you for like $300.00. If I were shelling out that much for a kit, why not just let them do it, LOL.
Good luck!
Good luck!
what are the major differences with ABEC-7 and ABEC-9??
SuperchargerRebuilds doesnt give any info. If im not mistaking, the ABEC-9 can run higher boost thus creating more power or is the power output the same just able to better hold a smaller pulley?
sorry, dont mean to jack the thread
Originally Posted by ABCVTEC,Jul 20 2008, 09:13 PM
I wonder if it's higher boost or more efficiency.
