removed turbo and car wont run right
Old 04-11-2018, 06:26 AM
Lance E's Avatar
Default removed turbo and car wont run right
hey guys.
i pulled my greddy turbo kit off and installed stock style injectors, plugs and the intake tube and for some reason i can seem to get the car to run smoothly. it will start and die then start and run but very rough fluctuations in idle and when i try to drive it it bogs hard and doesnt have any power. when it was turboed it ran just fine except for the exhaust leak on the manifold connection to the head. any ideas? any one in the local area willing to take a look and see what i forgot?
Old 04-11-2018, 06:45 AM
Mijae007's Avatar
Did you put your ECU back to stock?
Old 04-11-2018, 07:07 AM
Lance E's Avatar
yes. i pulled the emanage off and plugged the stock harness back to the ecu. ive had the battery unplugged multiple times. am i missing anything?
Old 04-11-2018, 07:47 AM
nguyen365's Avatar
Did u plug back in all the sensors?
Old 04-11-2018, 09:42 AM
Lance E's Avatar
yes? i dont see anything missing? i did the vac sensor thing and the took the missing link thing off of the map sensor. that was the only things that came off? do o2 sensors make a diffeeence?
Old 04-11-2018, 12:42 PM
Mijae007's Avatar
I mean everything should be reverted back to stock. Map sensor, spark plugs (if gapped for turbo), injectors, etc
Old 04-11-2018, 02:55 PM
AP1Chief's Avatar
Sounds like Map sensor is not correct.
AP1Chief's Avatar
Do you have Factory 02 sensors plugged in?
Old 04-11-2018, 04:13 PM
MARK AUS S2K's Avatar
Doesn't run right as in it is now slow as f@#k? This is stock power mate :-p
Old 04-11-2018, 06:59 PM
Lance E's Avatar
no its not like stock power, when i give it gas it bogs and almost stalls. even caused the cel to come on and blink. another member is saying it might be the shitty ebay injectors i bought
Quick Reply: removed turbo and car wont run right
