Replacing Fuel Pump Wiring Intank
Can someone inform me how to get the connectors out of the plastic fittings? The one in the third picture is giving me fits.
It looks like it should swivel open but I can not get it to budge.
This helps:
https://goo.gl/images/ub1cij
you want to lift up on the skinny grey tabs then the orange piece should pop out with some prying.
I ended up at the local electronics shop and had a professional crimp and solder the wires for me. I ended up using all 10ga for the system except in the tank where 12ga worked fine.
I see you're sorted now but if I remember correctly when I did mine (SOS kit) I used a tiny screwdriver to pry that retention bracket up in between the middle of the black plug and the bracket itself.
ScienceofSpeed
May 14, 2014 04:49 PM
jco2301
Jan 28, 2014 04:28 PM
