S/C Question
Got a got a CR with 8,000 miles and I want to install the Kraftwerks high boost kit, but first I have a couple of questions for those of you with FI backround. I've already bought the following mods to support the upgrade - comp clutch stage 2 kit w/flywheel - T1R 70mm Evasive Motorsports Dual - Okada Project coilpacks....I am also looking to add Thermostat/Fan Switch, T1R header and a berk hi flow cat converter.
1. Is it ok to boost a car with such low miles? I know the car is not fully broken in and I originally wanted to wait till I hit 30K but my obsession is not allowing me to hold off.
2. Do boosted cars hold up well on long trips 4+ hours - overheating ect.-? I ask this because I'm going to drive this every day for the next 8 months with plenty of long south texas road trips mixed in.
3.Is it necessary to upgrade to a Big Brake kit? Will upgraded pads be OK?
I am currently torn on what to do.
1. Quit messing around and Boost it now.
2. Add an intake and a Hondata toda reflash along with my supporting mods....wait a year then boost it with more miles on the engine. This should keep me happy while the car is still a DD.
any help is appreciated
Originally Posted by WashabiS2K,Jul 20 2008, 08:31 PM
the CC stage 2 won't be enough for the high boost setup. Mine is slipping and I'm only making a measly 335whp.
guys at sos said it was good up to 400whp .... maybe i should go with the 6lb pully?
coil packs were a waste of money for your application.
do the fan/themostae mod 1st - it really make a difference here in florida
your motor was broke in after the first 500 miles - beat on it!
long drive trips should be no problem, if the car is tuned and running correctly - it should run as good or better than stock.
my opion on brakes - upgrade to stainless lines and high temp fluid -
leave intake alone dont even mess with a gasket - waste of money!
the kraftworkers kit comes with a hondata reflash so just do the following and you would have a dependable DD that is fast
upgrade clutch (you can get a stainless steel feed line for this also)
install fan & themostate low temp mods
install stainless steel brake lines and new fluid
Kraftworkers kit.
Kraftworkers kit.
Kraftworkers kit.
Kraftworkers kit.
