SC: Owners
Old Oct 6, 2006 | 05:49 PM
SC-SUZUKA's Avatar
Default SC: Owners
What clutch kit combo do you recommend for 400RWHP? which PP also?
Old Oct 6, 2006 | 06:00 PM
kane.s2k's Avatar
http://automotivespeed.com/product_info.ph...products_id=141
This would probably work for you since you are S/C. It is a complete kit...PP, bearing, disc, alignment tool included.
Old Oct 6, 2006 | 06:22 PM
Sideways's Avatar
That's a nice clutch.
Many of us have gone the ACT pressure plate, lightweight flywheel (several brands including Comptech and Spoon) and factory disk. I have been driving on this clutch for almost 5 years and it holds fine. I think it is rated at 490 ft lbs.
Old Oct 7, 2006 | 04:08 AM
SC-SUZUKA's Avatar
You have the one that Kane recommend me, or the ACT PP and OEM clutch with a light flywheel?
Old Oct 7, 2006 | 04:12 AM
EriS2k's Avatar
I have ACT Extreme Plate and OEM Disc and is not Holding Well!
Upgrading to 4 pad Race Disc
Old Oct 7, 2006 | 06:31 AM
bigpurp's Avatar
ACT PP, Toda flywheel and OEM disc here.
Old Oct 7, 2006 | 07:06 AM
John_Z's Avatar
HTG package
Old Oct 7, 2006 | 07:12 AM
smitdog's Avatar
My car is at inline performance at the moment gettin vortec'd to around 400ish hp .. and comptech flywheel act PP , oem disk and bearing .. i hope it holds up !! eri s2k just got me wondering if it will !!!
Old Oct 7, 2006 | 07:40 AM
kane.s2k's Avatar
Has a lot to do with the way you drive and how you drive. Some people have had the OEM setup and are over 400whp with S/C. The S/C units just seem to put less stress on the clutch kits than the turbochargers
The Competition Clutch Stage 2 seems to have equal or a slight bit more grip than the ACT HDSS. The stage 3 would offer a good bit more grip than that.
Old Oct 7, 2006 | 05:10 PM
Nugget's Avatar
Hey Sideways,
What do you think about this one.
http://www.kingmotorsports.com/category.aspx?cat=30
"HD Clutch Kit [ACT-HS1-HDSS]
S2000 (2000-2003)
S2000 (2004-2006) $ 735.00"
I am planning on going with a comptech lightweight flywheel.
Main difference is the use of the ACT disk compared to the factory disk.
When you changed yours out, did you use the same factory disk or buy a new one?
I just bought a comptech S/C and plan on building it to have at least 350 rwhp.
What are your thoughts? And where is the best place to buy the setup that you mentioned. Thanks,
