Science Of Speed Novi 1200
#35
That should be in the instructions. If you don’t have that, then get a hold of Chris at SOS and ask. You just loosen the idler pulley nut, turn the tensioner bolt counterclockwise, check the tension tight enough to turn the belt 90 degrees on the long end, and tighten the idler pulley nut.
#36
So the supercharger is in. Also wired my boost gage and a/f gage. Ill drop pictures below. I have a question about uploading a basemap through my aem ems series 2. Theres a basemap for an ap1 centr. supercharged intake exhaust header ext. with 700cc injectors. I have 1050 injectors so ik my car wont run with this calibration. Can this basemap be edited to fit my fuel system.
(Side note: i dont plan on leaving the car on this map. Just want to use it to get to my tuner) ive used hondata software before but not aem so i wanna know what options there are. Thank you
#37
So i have goodies coming this friday and am excited to install everything. I have the supercharger as the title shows and also some aem a/f and boost gages. Does anyone have any suggestions on where they tied the wideband to? Also any suggestions on things to lookout for while installing the SC to avoid any headaches.
#39
michaell1212 (03-12-2020)
