Sensor for Pre-Turbo IAT/MAP Measurement
On another forum one of the moderators was fairly adamant about the importance of measuring temp and pressure at various points on the inlet track to measure intake effectiveness. In the end, he though pre-turbo was most important. He recommended this fairly low cost Bosch combination 1 bar MAP and IAT: https://www.bmotorsports.com/shop/pr...oducts_id/2270.
Is anyone taking those measurements? |
That makes no sense to measure pressure pre turbo. Temp, maybe but I wouldn't consider it very useful. Common sense would tell me intake temp/pressure would be most important as close to the throttle body as possible. The s2k IAT sensor tends to heat soak so putting it on a charge pipe would be the most accurate.
The discussion had been about cold air intakes on turbo engines. In this case, a rather detailed response indicated without the pressure and temp readings it was hard to evaluate how the system was operating. What the actual pressure drops were. How efficient the turbo and intercooler were.
He had posted an unlabeled graph measurements of different cold air intakes at different mass flow rates. They showed that the pressure drop increased significantly at higher flow rates. https://cimg1.ibsrv.net/gimg/www.s2k...2bc24edb8c.jpg A quick calc shows the difference between 90F air with a 0.25 psig pressure drop vs 120F underhood ar with a 1.25 psig could be a 50F hotter turbo discharge temp. Stealth 316 - Turbo Outlet Temperature |
Originally Posted by DavidNJ
(Post 24481004)
He had posted an unlabeled graph measurements of different cold air intakes at different mass flow rates. They showed that the pressure drop increased significantly at higher flow rates. https://cimg1.ibsrv.net/gimg/www.s2k...2bc24edb8c.jpg A quick calc shows the difference between 90F air with a 0.25 psig pressure drop vs 120F underhood ar with a 1.25 psig could be a 50F hotter turbo discharge temp. Stealth 316 - Turbo Outlet Temperature Relevant information: Compressor Efficiency and More Turbo Tech: Calculating Compressor Flow Turbo Tech: Calculating Turbocharger Compressor and Turbine Performance Advantage with the New Honeywell Garrett GTX Gen2 |
edit: double post
Originally Posted by spdracerut
(Post 24481159)
Colder air intake into a turbo reduces required compressor power > reduce turbine power > reduced back pressure > more power. Also quicker spool, faster transient.
Relevant information: Compressor Efficiency and More Turbo Tech: Calculating Compressor Flow Turbo Tech: Calculating Turbocharger Compressor and Turbine Performance Advantage with the New Honeywell Garrett GTX Gen2 "reduces required compressor power > reduce turbine power > reduced back pressure > more power" I'm wondering if this is true. The compressor usually seeks a specific intake manifold pressure controlled by the ECU and wastegate controller. As your articles state, required compressor power is a function of mass. Won't colder air require more power to compress the higher mass to the same pressure? The denser air will create more power though if higher cylinder pressures don't cause knock. A reduction in inlet pressure drop from ambient or reduced pressure drop across the intercooler will require less pressure gain, a lower pressure ratio, across the compressor because less compression is required to achieve the specified manifold pressure. That will require less power to drive the turbo resulting in lower back pressure and reduce heating in the compressor because of the lower pressure ratio. It won't increase mass flow. |
(Post 24481178)
I'm wondering if this is true. The compressor usually seeks a specific intake manifold pressure controlled by the ECU and wastegate controller. As your articles state, required compressor power is a function of mass. Won't colder air require more power to compress the higher mass to the same pressure? The denser air will create more power though if higher cylinder pressures don't cause knock. A reduction in inlet pressure drop from ambient or reduced pressure drop across the intercooler will require less pressure gain, a lower pressure ratio, across the compressor because less compression is required to achieve the specified manifold pressure. That will require less power to drive the turbo resulting in lower back pressure and reduce heating in the compressor because of the lower pressure ratio. It won't increase mass flow. You are also correct in that reducing pressure drop before the compressor inlet and through all the piping and IC will reduce the compressor pressure ratio requirement which in turn reduces compressor power requirement leading to more power. |
