Seriously Kraftswerk? WTF.
#91
#92
Regardless I view it important to set the proper belt tension/fastener torque specs/assembly methods as close and as often as possible not only for proper operation but able to rule something out if a problem does arise. Granted I'm an engineer and that's just how I think based upon things I've dealt with at my job so take it with a grain of salt n obviously engineers do not make proper designs from the get go at times
#93
SOS i haven't heard much about in terms of issues. I'd personally go with SOS if I was doing it all over again. KW was substantially cheaper though.
#94
comptechs and vortechs had their fair share of issues. But they also had less power and were released a long time ago. People have had vtec solenoid bolts come out on vortech kits. Blowers failing; etc.
The old Novi 1000 in the comptech kits is not going to get you much past 400whp, but those blowers are long gone and any of the current gen blower kits that utilize novi blowers give you an option to run the tried and true Novi 1200 which has proven to deliver 500whp+ with E85 or water/meth injection on pump. 565whp has been the highest ive seen with this blower to date. The old school Novi 1500 by the same user made over 600whp.
#95
Got more news.
The guy who is "helping" (ya right) me out is Douglas Haley from KW Customerservice department
ok so talked with this guy and he kept tryna sell me the 30mm kit. I finally got him to say that "the current kw kits can't handle the torque produced by your blower. The 20mm kit is a temporary solution. The 30mm kit will fix all your issues."
WTF. seriously? You produce a kit that's you say can handle all the rotrex blowers. Then when people began snapping bolts and belts you decided to reengineer the POS belt and sell the new kit as a solution to the old. MF.
also he told me to download an app and measure the hertz like a MF VIOLIN !!!!
if I was an engineer at this place I woulda fired myself.
Stay tunned on what hat these guys have to say
so so upset right now as my buddy needs to prepare for GTA SLB !!
#96
Got more news.
Stay tunned on what these guys have to say
#97
Guess I'm one of the lucky ones. Original KW (O.Jackson ) designed kit on mine since they came out put the kit on at 16k miles now at 75K. Think I was like No. 10, Upgraded gates auto-tensioner, and pulley bearing as well as belts for me to keep it going strong have just been treated as wear items that I got used to replacing every yr. Funny thing I have learned with my setup is that you become tuned into how it should run or sound after so many years.
I need to ask my local buddy who has that cogg design how it's been running, I will say this yrs ago when I went to kraftwerks and spoke with Oscar Jackson he was a pretty sharp guy who did a a lot of homework on Autotensioners and adjustable design and said he was sold on the design because of its simplicity ease of service.
#98
Also a relatively lucky one here and i'll chime in.
DIY installed originally on a 20mm pulley setup, managed 4k on a used belt that previously had about 10k on it ( and was on when the supercharger shaft snapped prior to my ownership ) Then it snapped clean under light driving, tried another brand of belt from Medway ( Dunlop ) that lasted about 800 miles due to the heat and being made of rubber. One thing I did notice with the original 20mm Kraftwerks belt is it was terribly dusty and gathered around the VTEC solenoid and cam cover. Can only assume this was the belt braking down over time.
That point I purchased the 30mm kit, one of the first I understand. Upon receiving the pulleys, I measured the height of them and spacers to match them up and ensure there would be no belt rubbing/run out issues, found there to be naff all difference in height difference, just double checking.
Now on 30mm and done about 5k and no issues thus far and no dust to be seen either!
REALLY is critical the tension on this belt setup. You almost need to set it too lose when its cold, to the point you can very nearly pull it off the crank pulley. When started cold the belt will flap and chatter at the longest points of travel between the crank pulley and the 2 lower pulleys, but as you heat the car up, it gets tighter, When it's warm, I usually get about 1/4-1/2" of twist in the middle of the longest stretch of the belt. Purely based on feel this is, I think that's the issue, some peoples version of tight is lose and vice versa.
Motor mounts aswell. Even though the supercharger is mounted on 3 points on the engine and being connected to intercooler pipework, the flex and torsion of that fighting against the intercooler pipework will have an effect somewhere down the line.
That's my 2 pence on the matter anyway. Hope he has a bit more luck with it soon.
#99
Just got a response for KW after a week. They are trying to sell me their 30mm kit. Seriously? My buddy has paid 5k already. And he is broke. Wat a$$holes.
Then he responded if I installed it using hertz. Anyone have any idea what kw means here? We r measuring sound now? Wtf. Stay with a torque number.
RAIN H8R
07-07-2015 07:07 PM
dan_bourne
05-23-2012 10:15 PM
