So far for my turbo set up
OKay I got it only tuned up to about 10psi but has went up to 11psi at about 6k then down. I got 369rwhp on pump 93 at 10psi. I was told that he doesn't want to boost it up now because I have blow by which also popping the dip stick So I'm thinkin of gett the T1 race crankcase catch can
I figure that he probably could lean it out just abit more it would be better. Any suggestion to get my 10.4 A/F ratio down from idle without having issue starting up when cold?
here's my list
AEM 1052U
AEM peak and hold injector driver
RC 1000cc
AEM FPR
Inline pro 3mm HG
OBX Header
Garrett GT35r
3" down pipe
No cat (might put on in cuz im sick of the black stuff on my back end)
Comptech cat back (sounds quiet lol)
Cheap FMIC but get a Inlinepro 600hp FMIC
2.5" pipping
OMNI 4 bar map sensor
KOYO Rad
170 degree thermostat
Canton oil filter relocation kit with a full race banjo bolt
Universal oil cooler
Tial 44mm wastegate dump back into down pipe
OBX 50mm BOV
ACT PP and street disc
Comptech flywheel
theres more but can't think of it
Ordered, on its way
AEM water/meth injection
AEM tru boost controller
Saving up for a inline pro diff kit before I blow the stock one.. never launch it yet with this set up and don't plan on it til i get the kit.
here's the bay
here's my list
AEM 1052U
RC 1000cc
AEM FPR
Inline pro 3mm HG
OBX Header
Garrett GT35r
3" down pipe
2.5" pipping
KOYO Rad
OBX 50mm BOV
Comptech flywheel
Ordered, on its way
here's the bay
well, for a low boost level, a smaller than 3" exhaust ( a guess ), and a 3mm hg those numbers are really good I would say. I havent really seen anyone using the obx manifold, looks like a fullrace manifold actually so it probably flows fairly well.
People say to turn the dipstick around 180* to keep it from popping out. I bet at 15psi or so you could be around 425whp or so which seems respectable and you do have some power left in it i would guess.
Originally Posted by CU Nick,May 12 2008, 05:00 PM
Nice set-up and some pretty decent numbers. I would think you could run a little more PSI with the larger headgasket and break 400whp without a problem.
The only downside about obx is that I had to cut the old v band flange for the 44mm wastegate then put the new one on and only one port was off by 1/16"... other than that the welds are pretty decent.
Thanks for the tip with the dip stick.... has anyone turbo with out a catch can with over 400whp?
Originally Posted by samus143,May 12 2008, 05:23 PM
^^^Very nicely put together, what made you decide on the OBX manifold? Keep us posted on the efficiency between the old and new intercoolers also.
That's awesome!!
I just recieved my inline pro kit and was concidering taking my car to Beyond Redline to install and tune too.
Let me know how their service is and how well they tune!!!
Nice to see another turbo s2k in Wisconsin!!
