SOS 3" Pulley - Cut Grooves Photo
I'm preparing to dyno my S2000 with a 3" pulley on a NOVI1000 and it sounds like belt slippage is going to be an issue. In an attempt to avert possible issues on the dyno, I'm thinking about cutting grooves into the pulley ahead of time. Does anyone have photos of exactly how this needs to be done to improve belt grip?
There is really only one way to do it I found, cut laterally across the grooves, and deep enough to be effective with the right size Dremel cutting wheel. I did a cut about every 1" or so spacing if I recall. But I don't think there is any set rule here, this is a custom job. Do what you think will work best.
shamusodoofus (03-25-2019)
Richard racing pulleys are a bit more elaborate then simple cross cut groves, they are actually semi hollow pullies, where material is machined out of them and the cuts on top actually show light through them from underneath. This not only makes them lighter pullies, but I wonder if this has an impact on performance, relieving positive pressure aiding in the belt grip. Not sure if that's just my theory or actual intent. Either way, cross cutting some make shift groves on a standard pulley is likely worth doing.
You could do something like this to your pulley.
https://www.dragzine.com/tech-storie...rip-carbinite/
And here is the Co. that does this
High Friction Metal Coatings - Improving Machining Clamping Force | Carbinite Metal Coatings
This is not new technology(it works) but I have not seen anyone on here talk about it.
Rod
Rod
Rod
Rod
You will always have some amount of belt slip by design unless its a cogged system, and those have their own set of issues, like breaking things.
